  • kuissa Friend
    #169646
    Hi there
    I am new with Joomla (1.7) and setting up fairly simple site.. Please have a look at the page http://www.lapsukaiset.com/index.php/vauva/yleistae which summarises pretty much my current problems
    1. I am using the default layout and the submenu module is set for position “left”, however in some category blocks it appears on the bottom even though everything seems to be defined same way? What could be done wrong here?
    2. the article image is automatically resized only from the width and that does not look good –> how can I change that and what would be the best way of handling the images in category block? Also is it possible to handle e.g. how or where the contentslider on the bottom crops the images?
    4. Where can I change the text “more articles…” and remove the button thingies (start/next/previous/end) below that?
    Thank you so much in advance!
    TomC Moderator
    #419165
    Greetings:
    Let’s try to tackle one issue at a time for you . . . .
    First of all, what I will need is temporary access to your site administration backend – to check out the settings you currently have. Can you send me a temporary login via PM (private message)?
    kuissa Friend
    #419615
    FYI: PM sent on Friday
    Thanks for your help in advance!
This topic contains 3 replies, has 2 voices, and was last updated by  kuissa 13 years, 3 months ago.
