  • mongini Friend
    #141485
    I have ja zeolite with joomla 1.5.10 + Virutemart 1.1.3 + Artio Joomsef 3.2 Registered + Joomsef Plugin virtuemart.
    I have two problems:
    1º- Check out in virtuemart doesn´t work, when I click goes to homepage
    2º- In product details in virtuemart when I click add to cart appears 404 error.
    Thaks
    nguyenhuu quang Friend
    #306226
    it is problem with Your SEF.
    I have FIXED it for you. pls check it
    cusack01 Friend
    #308484
    Hi I am having the same problem. What is SEF???
    ‘How do I fix it?.
    #308693
    pls send you liuve site/
    thanks
This topic contains 4 replies, has 3 voices, and was last updated by  nguyenhuu quang 15 years, 6 months ago.
