Creaktor Branding Agency Friend
- May 2012
- 2 times in 2 posts
March 9, 2017 at 12:21 am #1016422Compile LESS to CSS failed
templates/ja_mono/acm/container-slideshow/less/style.less .translateY is undefined
Inside the style.less file is no .translateY defined. I can’t find the sollution to this problem.
www.creaktor.com
Creaktor Branding Agency FriendCreaktor Branding Agency
- May 2012
March 9, 2017 at 12:22 am #1016423This reply has been marked as private.www.creaktor.com
- May 2012
March 9, 2017 at 2:07 am #1016470This reply has been marked as private.www.creaktor.com
Saguaros ModeratorSaguaros
March 10, 2017 at 6:52 am #1016997Hi,
The FTP account doesn’t work, could you update again?
- May 2012
March 10, 2017 at 10:16 am #1017085I updated the credentials
www.creaktor.com
March 13, 2017 at 3:14 am #1017548Still no luck. I use FileZilla ftp client to access
- May 2012
March 13, 2017 at 9:16 am #1017684This reply has been marked as private.www.creaktor.com
March 14, 2017 at 3:36 am #1017952Here is my IP: 113.190.254.239 , pls add an exception for it.
Thanks.
- May 2012
March 15, 2017 at 10:04 am #1018546Done. You should be able to login now.
www.creaktor.com
March 16, 2017 at 4:54 am #1018849Hi
I updated this rule:
.translateY(@y) { -webkit-transform: translateY(@y); -ms-transform: translateY(@y); // IE9 only -o-transform: translateY(@y); transform: translateY(@y); }
into the file: templates/ja_mono/acm/gallery/less/style.less
You can check it now.
- May 2012
March 17, 2017 at 5:32 pm #1019551On the homepage the clients slider is now broken. With all the logo’s
www.creaktor.com
- May 2012
March 17, 2017 at 5:38 pm #1019552When I first visited the site, the logo’s where all below eachother with a visual col span of 12. Now it’s fixed. Why does this happen. Does this happen for all new clients? Or only the first visit after a less to css compilation?
www.creaktor.com
This topic contains 12 replies, has 2 voices, and was last updated by Saguaros 7 years, 9 months ago.
