  • peppericci Friend
    #968716
    In a site I built the plugin works properly for English but doesn’t works for Italian
    If you want to add a filter to the descriptions in the Italian also appear in English.
    I checked the English descriptions are associated only to articles in English
    Languages ​​are set correctly for languages, infact if I filter checking an English description I do not get results in Italian!
    Italian: http://prntscr.com/ciofw9
    English: http://prntscr.com/cioggd
    Can someone help me?
    Tnx
    Mo0nlight Moderator
    #969663
    Please post your site url and admin login.
    I’ll check your site for you.
    Regards.
    peppericci Friend
    #969945
    I can’t see the reply by Mo0nlight !
    peppericci Friend
    #971035
    Mo0nlight Moderator
    #971373
    Hi.
    The problem come from wrong configuration for some content items.
    For example. K2_Item id : 688 with title : C82 The language is English but the category you assign to is Italian. So the item got the extra field for Italian. for the Bottle: You need to edit the item id: 688,1013,1014,1016,1022,1023,1024,1025,1028,1029,1030 ,1031,1032,1033,1034,1035,1036,1037,1038
    I edited jar, jerrycan.
    peppericci Friend
    #973490
    I read just now because I have been away.
    First thanks
    I have not entered the articles and I did not think that the mistake was there (I limited myself to check that they were in Italian or English: -S )
    Thanks again, I also saw the aggiormento, as soon as I’ll install it.
    😉 pEppE
This topic contains 5 replies, has 2 voices, and was last updated by  peppericci 8 years, 1 month ago.
