  • mayhesla Friend
    #135386
    Hi.
    Long time no talk btw 🙂
    Back in business over here and i’m currently testing the ja_sanidine template.
    I have one problem so far. It’s when i try to edit posts in fireboard. The page layout gets messed up and its impossible to take any action in terms of editing – see attached image.
    Anyone else having this prob?
    I’m on joomla! 1.5.8 – fireboard 1.0.5rc2 and cb 1.1
    I have made some changes that where posted in this forum regarding latest fb version etc…but still the layout is messed up.
    Thx for helping out 🙂
    1. error-image
    mj1256 Friend
    #279228
    wheres the image
    mayhesla Friend
    #279229
    it’s attached….
    problems viewing it?
    mj1256 Friend
    #279230
    strange, it was not there before
    mayhesla Friend
    #279312
    hmmm…anyone out there that have a tip on this?
    In fact,, i cant even post a new item in the forum. everything is messed up.
    need help = thanx
    mj1256 Friend
    #279314
    have you tried setting it up to use a different fireboard template so we can find out if its just the template or the whole install that is messed up
    mayhesla Friend
    #279412
    Hi again,
    ouch, no i hadn’t done that – wich i obviously should 😉
    After setting the template to default – the error/problem is still there. I followed every step on how to upgrade fireboard(i got ‘green light’ on every test after the install = no error report after install), but it is obviously that if one wants do do anything on a joomla install – it will cause problems no mather what.
    I wanted to get my site up and running again – now i just want to delete the whole J-crapp lol
    If you want mj1256 – i could give you acccess to my site admin area so you could perform an error check etc…if u want of c.
    thanx again for helping (i have opened a topic at bestofjoomla as well of c)
This topic contains 7 replies, has 2 voices, and was last updated by  mayhesla 16 years, 1 month ago.
