  • Ninja Lead Moderator
    #994505
    About the problem event page, it looks like you have changed it from templates/ja_charity/html/layouts/joomla/content/item/event.php file and you need to rollback it with original file
    About the problem on Home event. I fixed it directly on your site and you can see it from templates/ja_charity/acm/news-featured/tmpl/event-slider.php file
    find and change
    <?php
        $max_length = 80;
        $s = $item->introtext;
        if (strlen($s) > $max_length) {
        $offset = ($max_length - 3) - strlen($s);
        $s = substr($s, 0, strrpos($s, ' ', $offset)) . '...';
        echo $s;
    to
    <?php
      $max_length = 80;
      // Allow <p> and <a>
      $s = strip_tags($item->introtext,'<p><a>');
      echo $s;
    goldfinder Friend
    #994622
    Thank you, you rock 😀
This topic contains 2 replies, has 2 voices, and was last updated by  goldfinder 7 years, 11 months ago.
The topic ‘Problems with events’ is closed to new replies.
