May 6, 2009 at 10:48 pm #140959
The footer is cut to the size of the web and not complete.
How do I solve this problem?
I show a picture of question
thanks
dizajn75 Frienddizajn75
- December 2008
- 3 times in 1 posts
May 9, 2009 at 7:20 pm #304162I am also having same issue.
I am looking for solution, as it looks really bad.
I think this is kind of issue that MUST be solved by Joomlart team.
If anyone knows how to resolve this, PLEASE HELP. Thanks
mfcphil Friendmfcphil
- 388 times in 133 posts
May 9, 2009 at 8:26 pm #304165Ok submit a ticket and ask the team for the IE8 code to sort this out for you. until you get a fix try this temporary solution
go to your admin and find your index.php file
add the code into the head of that file <meta http-equiv=”X-UA-Compatible” content=”IE=7″ />
1 user says Thank You to mfcphil for this useful post
- December 2008
May 9, 2009 at 8:47 pm #304166<em>@mfcphil 128026 wrote:</em><blockquote>Ok submit a ticket and ask the team for the IE8 code to sort this out for you. until you get a fix try this temporary solution
add the code into the head of that file <meta http-equiv=”X-UA-Compatible” content=”IE=7″ /></blockquote>
I think apusweb should made a ticked or post it to support, so that they also read this issue.
- December 2008
May 10, 2009 at 10:20 am #304202<em>@mfcphil 128026 wrote:</em><blockquote>Ok submit a ticket and ask the team for the IE8 code to sort this out for you. until you get a fix try this temporary solution
Is this index.php located in
joomla folder or
in joomla/templates/ja_tronaThanks
1 user says Thank You to dizajn75 for this useful post
- December 2008
May 10, 2009 at 10:23 am #304203<em>@dizajn75 128071 wrote:</em><blockquote>Is this index.php located in
joomla folder or
in joomla/templates/ja_tronaThanks</blockquote>
I think it is in this folder
joomla/templates/ja_trona -
This topic contains 7 replies, has 3 voices, and was last updated by apusweb 15 years, 7 months ago.
