rodro Friend
rodro
- November 2011
November 8, 2015 at 6:05 am #732133Hello,
I was configuring megamenu and when I returned to the site, the forum (kunena) was all different, not showing its menu and kind of without template. I checked and (for me) it seems to be all normal.
The thing is that I didn’t do anything, not even in megamenu config, about the forum.Thanks for your help.
- November 2014
- 3854 times in 3563 posts
November 9, 2015 at 6:58 am #754019Hi,
Have you solved the problem on your site? I see the Foro menu item on your site is working fine like the configuration from Forum page from our demo: http://ja-techzone.demo.joomlart.com/index.php/en/forum/index
rodro Friendrodro
- November 2011
November 10, 2015 at 12:36 am #754094No.. it’s still the same.. (attached images)
- November 2014
November 10, 2015 at 4:46 am #754113<em>@rodro 501500 wrote:</em><blockquote>No.. it’s still the same.. (attached images)</blockquote>
It seems that the css style of Kunena is not loaded on your site.
I added it into templates/ja_techzone/tpls/blocks/head.php file with code
<?php
if (is_file(T3_TEMPLATE_PATH . '/local/css/extras/kunena.css')) {
$this->addStyleSheet(T3_TEMPLATE_URL . '/local/css/extras/kunena.css');
?>Now, you can see it’s working on your site.
rodro Friendrodro
- November 2011
November 10, 2015 at 6:04 am #754121Thanks, why would that happened? just from nothing.. and why has the kunena menu disappeared as well? it’s not there anymore… also, when trying to configure or edit categories, they have gone as well, but they are shown on the front end, but can’t find them at the back end..
- November 2014
November 10, 2015 at 9:16 am #754135I switched the template style to default style of Kunena but it still gets the same problem.
About the configuration of Kunena forum, you should raise that request to Kunena forum maybe you will best answer from there.
This topic contains 6 replies, has 2 voices, and was last updated by Ninja Lead 9 years, 2 months ago.
