  • pierotemplate1 Friend
    #154558
    RESOLVED After the recent problems experienced with frei chat, the system still not working, in particular:
    – If I move an item from a “type of voice” to another, it vanishes and appears as deleted in the Admin dashboard.
    – Creating new forums and assigning them to the “types of voice”, they do not appear in the window to insert new items, therefore you can not create new item.
    – in the creation of new items, there is a single forum, although there are others correctly allocated (in the voice, “problem” are not indicated forums)
    Should I publish the site next week, but I can not use this component. I also remember that I removed the component frei chat Ticket ID: RAA-901676 —– RESOLVED —–
    Anonymous Moderator
    #356530
    Please see my answers as below:
    1. If I move an item from a “type of voice” to another, it vanishes and appears as deleted in the Admin dashboard.
    >> If you move an item from “type 1” to “type 2” in box “Overall Statistics” of admin dashboard: Total of ‘Type 1’ will be decreased and “type 2” ‘s will be increased. This is working as designed. No issue found here
    2.
    – In the creation of new items, there is a single forum, although there are others correctly allocated (in the voice, “problem” are not indicated forums)
    >> It seems that you do not select POST PERMISSION , VIEW PERMISSION * correctly
    Kindly check and get back to us for further help.
This topic contains 2 replies, has 2 voices, and was last updated by Anonymous 14 years, 3 months ago.
