  • projectosglobais Friend
    #196220
    We are having troubles to put Google Maps to work. The code is on the Notes field, in the Contacts Component.
    The problem is that the map doesn’t show up properly. You can see that on the attached image.
    1. map
    I just tried to access contact page in your site and see that the map’s displaying fine now: http://prntscr.com/34t18w
    #528469
    Sorry, that’s because we changed to another plugin. To avoid this, we created a copy of the site in:
    http://www.projectosglobais.com/ja_tests
    If you try again now, you will see the problem.
    Thank you,
    #528964
    Any news about this issue?
    Thank you.
    Which version of JA Google Map plugin are you using? Please try to have it updated to the latest version.
This topic contains 5 replies, has 2 voices, and was last updated by  Saguaros 10 years, 8 months ago.
