fmolina Friend
fmolina
- August 2013
March 1, 2016 at 9:36 pm #893095Hi.
In purity III I make a different size for the logo (I change in template.css the size of the logo for adjust the new sizes) but you can see problems in the image with padding and with the words of main nav and line botoom.
Can you help me?Thanks.
pavit Moderatorpavit
March 1, 2016 at 9:39 pm #893098Hi there
Please post a link to your website so we can check it and suggest a modification
fmolina Friendfmolina
- August 2013
March 2, 2016 at 6:52 am #893293sorry but now I have a local site.
March 2, 2016 at 7:00 am #893298sorry but now I have a local site.
If we cannot check your website we cannot say what is wrong with it since you applied changes to css files
Would be better to post your website on a public host from where we can access it and verify errors
Best regards
- August 2013
April 12, 2016 at 10:58 am #914837Thanks.
I now have a public site.
This is:
http://hemeromu-cp157.webjoomla.es/gatell/index.phpYou can see the problem.
Thanks a lot.
April 12, 2016 at 3:05 pm #916675Hi
Try to add this to your custom.css file in this folder /templates/purity_iii/css if you do not have it you will need to create a new one
.t3-mainbody { padding-top:40px!important; } .navbar-nav { margin:15px!important; } .navbar-nav > li > .dropdown-menu { margin-top:25px!important; }
Best regards
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 5 replies, has 2 voices, and was last updated by pavit 8 years, 8 months ago.
Problems with height and padding
