  • sergiosp Friend
    #726189
    Hello Team! I have problems with the home and logo.
    1) change the name: Templates Edit Style / theme / Site Name and the site disappeared!
    2) when you change the logo this was very small. I need that logo will look bigger and in the center of the web. The measures that put the logo is 170×170, if you can not see in this measure could put it in a slightly smaller measure …
    Kind regards
    sergio
    Ninja Lead Moderator
    #754782
    Hi sergio,
    I set the configuration directly on and added the css style into templates/uber/css/template.css file
    + Configuration from template manager: uber – [University] Home template style to default
    + Css styles
    @media (min-width: 1200px) {
    .uber-header .row .logo {
    width: 90% !important;
    div.logo-image {
    float: none !important;
    width: 15% !important;
    margin: 0px auto !important;
    .logo a {
    height: 170px !important;
    div.logo-image img {
    max-height: 170px !important;
    margin-left: 100px;
    and now, your site is working fine
    sergiosp Friend
    #754996
    Dear Ninja Lead,
    Thanks for your effort !, I see that part of the problem is solved! But I still see the home without any design, they disappeared all modules of the home. you may help me on this?
    Thanks friend!
    sergio
    #755005
    Please look at the screenshot below
    I didn’t see the module assign with homepage on your site. You can test it with format: your_domain?tp=1 and you have to assign the module to homepage on this case.
    sergiosp Friend
    #756549
    Dear Ninja Lead,
    I already did this and now there are as follow, I see shows me the position of the modules, but nothing else, I do not understand what happened, but I still see the home page as the default. You can help me solve this?
    #756598
    I added the Uber Statistics module with uber-home position under Sutna page on your site, now you can see that module is showing on your site
    You can add new other modules with uber-home position under Sutna page
This topic contains 6 replies, has 2 voices, and was last updated by  Ninja Lead 9 years ago.
