July 17, 2009 at 8:06 am #142813
I have problem with menus position in IE8, all other browsers working fine. Please see page Location for example at:
Menu Location should be at position right as in Accommodation page.
Second problem is with Reservations page (Our rooms tab for example). Content spreads bellow the footer. And again, if I put menu at this page I have it misplaced as in Location page.
As you can see content on both pages are in custom modules.
July 18, 2009 at 5:50 pm #311452OK, I solved the problem, it is the compatibility issue as in previous post answer by mfcphil. 😀
wiery Friendwiery
- July 2009
- 36 times in 30 posts
July 19, 2009 at 12:09 am #311475I hate internet explorer! Why cant all browsers work the same way??????? It would save us all so much time and headaches.
hawver Friendhawver
- February 2008
- 13 times in 12 posts
July 19, 2009 at 8:24 am #311489IE8 is making a great move towards compatability with other browsers with following the CSS guidelines as they were defined by the w3 organization. Thats why sites may look different if you move on from IE7 to IE8. I hope in the future all browser will follow the guidelines the exact same way. That will make the live of a web developer a lot easier! 🙂
wiery Friendwiery
- July 2009
July 19, 2009 at 2:37 pm #311530<em>@hawver 137279 wrote:</em><blockquote>IE8 is making a great move towards compatability with other browsers with following the CSS guidelines as they were defined by the w3 organization. Thats why sites may look different if you move on from IE7 to IE8. I hope in the future all browser will follow the guidelines the exact same way. That will make the live of a web developer a lot easier! :)</blockquote>
I have noticed it is getting better. Lets hope ie9 is fully css compliant. Maybe even css3…
July 19, 2009 at 4:08 pm #311536Hopefully IE will be fully compliant, but in meantime we have to spend ours trying to find what’s wrong… Actually, I think IE was intentionally buggy and point is when you use IIS and all of the Microsoft tools, everything is working fine 😉
hawver Friendhawver
- February 2008
July 19, 2009 at 10:21 pm #311557Does frontpage have some kind of template generator for joomla?! 😀
wiery Friendwiery
- July 2009
July 19, 2009 at 11:27 pm #311568<em>@hawver 137354 wrote:</em><blockquote>Does frontpage have some kind of template generator for joomla?! :D</blockquote>
I doubt it. There might be something though. I know dreamweaver has something of that sort.
bennitos Friendbennitos
- May 2008
- 474 times in 407 posts
July 19, 2009 at 11:31 pm #311570And even if it does DONT use frontpage 🙂
There are a lot much better programs on the market who give you proper code, instead of the bad ones from frontpage.
wiery Friendwiery
- July 2009
July 19, 2009 at 11:38 pm #311576<em>@bennitos 137370 wrote:</em><blockquote>And even if it does DONT use frontpage 🙂
There are a lot much better programs on the market who give you proper code, instead of the bad ones from frontpage.</blockquote>
I second that motion. 😀
hawver Friendhawver
- February 2008
July 20, 2009 at 8:26 am #311600<em>@bennitos 137370 wrote:</em><blockquote>And even if it does DONT use frontpage 🙂
I was just joking. I’m using the oldschool, old fashioned, die hard text editor. 😀
This topic contains 12 replies, has 4 voices, and was last updated by danxy 15 years, 5 months ago.
