December 17, 2007 at 8:42 am #124441
Does anybody have problems using this template with IE7? I don’t have IE7, but my friend was looking the demosite, where I am using ja_genista and he said that the layout is a totally mess in IE7. Everything looks fine in IE6 and Firefox.
Still have the same problems with IE6 (links not working) , but if things do not work in every browsertype, or most used versions, I’m going nuts.
Khanh Le ModeratorKhanh Le
- November 2013
- 203 times in 131 posts
December 17, 2007 at 9:44 am #234720I’ve just checked this template on both IE7 and IE6 and it works fine. Do you mean the template is break on our demo or on your site?
Menalto FriendMenalto
- May 2007
- 531 times in 361 posts
December 17, 2007 at 9:55 am #234722<em>@Khanh Le 34658 wrote:</em><blockquote>I’ve just checked this template on both IE7 and IE6 and it works fine. Do you mean the template is break on our demo or on your site?</blockquote>
Khanh Le:
Go to the demosite.
Then to the Typography or Navigation link with IE6 and try to press any links in left or right modules there. Does it work for you?December 17, 2007 at 10:56 am #234724<em>@Khanh Le 34658 wrote:</em><blockquote>I’ve just checked this template on both IE7 and IE6 and it works fine. Do you mean the template is break on our demo or on your site?</blockquote>
I just downloaded IE7 to my laptop and it works fine. I guess IE7 showed it wrong, cause I changed the options from ‘wide’ resolution to ‘narrow’ and my friend tried to use the MY OWN demosite (not yours) in that very same moment..Or he did not clear his cache.
So everything seems to be fine now.. :p
Still got the problems with links..:confused:May 17, 2008 at 1:03 pm #249545Hi,
My top menu items overun the margin of the template in IE 7, as in they spill over the template. This is only experienced in IE 7 and not IE 6, Firefox or Opera.
What could be the problem?
Here’s the link:
http://www.shutterspeed.co.keMay 17, 2008 at 1:06 pm #249546AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 4 voices, and was last updated by mutwirik 16 years, 7 months ago.
Problems with IE7
