  • FELICE PREZIOSI Friend
    #161320
    After installing the quickstart JA Events I noticed that in IE7 and IE8 the font size is much larger than in other browsers.
    I found nothing easy to solve this problem.
    Is there any solution?
    Please, I need a quick solution
    Thanh Nguyen Viet Friend
    #381171
    Hello mate,
    I have just installed quickstart package of JA Events, and everything goes well on IE7 & 8.
    Please make sure you don’t increase font size on IE (press Ctrl+0 to reset font size to normal), or give me your site URL for further checking.
    Best regards,
    ThanhNV
This topic contains 2 replies, has 2 voices, and was last updated by  Thanh Nguyen Viet 13 years, 10 months ago.
