  • Arno Berwers Friend
    #150009
    Hi there,
    If I try to edit a job in the frontend, the application won’t save the job. IE8 is showing an error:
    Foutdetails webpagina
    Gebruikersagent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; Trident/4.0; GTB6.4; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; InfoPath.2)
    Tijdstempel: Wed, 31 Mar 2010 13:29:04 UTC
    Bericht: ‘task’ is leeg of geen object
    Regel: 1520
    Teken: 10
    Code: 0
    URI: http://www.XXX.nl/index.php?option=com_jajobboard&view=jajobs&layout=jaform&cid[]=502&Itemid=25
    It seems that the task is empty. Just left out the domainname as it is “work in progress”.
    Arno
    Anonymous Moderator
    #338684
    Hi there,
    It is very difficult for us to inspect the root without site info. Please update your credential at your original post following the guide via: http://www.joomlart.com/forums/topic/guidelines-for-efficient-prompt-help/
    Arno Berwers Friend
    #338706
    Hi Developer,
    I just updated the thread.
    Arno
    Anonymous Moderator
    #338747
    Hi Arno,
    Please cross check as I tried to access above given url in vain. Shall check again upon receipt of your valid information
    Arno Berwers Friend
    #338750
    Check again please.
    Arno
    Anonymous Moderator
    #338834
    Hi Arno,
    The site url is accessible now but FTP pathway is still invalid. Kindly login http://support.joomlart.com and view ticket ID#CTB-130994 to provide us valid credential there in for soonest solution
    Arno Berwers Friend
    #338845
    Check again please.
    Arno
    Anonymous Moderator
    #339162
    Hi there,
    Thank you for great patience. Please go Module Manager => select type “mod_jalist_job” => you will see two active modules therein. Click to edit each one and configure its position to stop at homepage.
    Repeat with the remaining module and refresh to see the changes
    Arno Berwers Friend
    #340036
    Hi developer,
    I do have a lot of problems in IE8 and I wonder if nobody else have the same problems. For example, if you search the jobs, try to select an employer. This doesn’t work in IE8, but does work perfectly in Firefox.
    Is this a known problem and what can we do about it as IE8 is broadly used?
    Arno
    Anonymous Moderator
    #340299
    Hi guy,
    I have fixed the bug: “Search the jobs, try to select an employer” for you.
    If there is any issue on IE8, please clarify and describe full details for a further help.
This topic contains 10 replies, has 2 voices, and was last updated by Anonymous 14 years, 8 months ago.
