  • Pankaj Sharma Moderator
    #991996
    Could u provide me description of the problem with an example URL . so that i can see what issue you are facing .
    italiawebsite Friend
    #992014
    I plugged in the url form, login and password. Him around message now.
    #992019
    Practically all "read more" in the articles of the blog does not go to the article.
    No error but brings back home.
    Even if I click on the title.
    So too any internal dynamic link to the site that links to internal pages.
    No problem with the main menu.
    I state that I also tried to disable the SEF settings, but nothing.
    For some internal pages I used the "way" to put them in a menu that then hide, but when there are news I can not remedy some way. 🙁
    Some idea? 🙂
    URL: http://www.stopviolenza.it
    #992020
    Some idea? 🙂
    #992097
    Kindly check the blog menu template style and see its layout .
    The layout should have a component section to display the menu output .
    If the layout is different kindly change the layout of this template style to default .
    Use One template style only for Home menu item that does not have the component section .
    And another for the whole site that use default layout , this way the issue will be solved .
    #992181
    Oh thank you so much!
    I set the same layout for all menu items. Now internal links work. Fixed links of the pits corresponding to the services pages.
    But they do not continue to operate the articles of the blog-news menu. If I click on "read more" do not open and end up on the home yet.
    #992184
    If the category of those articles does not associate to a menu it will open under Homepage .
    Kindly create a menu (category blog) select the category of your blog news items in it , so when u click on these article it will open under the menu you created not on Homepage .
    #992195
    Thank you.
    Therefore the menu item "News" = "category blog".
    I selected the category items "news".
    But I do not understand. Never happened to me. It does not work yet.
    #992210
    #992213
    The Home menu is also category blog and using news category , also you selected skip component for Home menu, this is a reason the article open under home menu and article not showing .
    Hope it helps .
    #992216
    Oh it was such a stupid thing. I did not think right.
    Oh understood.
    Thanks so much!
This topic contains 11 replies, has 2 voices, and was last updated by  italiawebsite 8 years ago.
The topic ‘Problems with internal links’ is closed to new replies.
