  • padre77 Friend
    #131069
    Im relatively new to joomla. I have built a site which looks fine in Firefox but does not display correctly in IE. Two of the modules appear at the bottom of the right hand side of the the page wehn viewed in Internet Explorer – they should be at the top.
    I would appreciate it if anyone could help me with this.
    The url for the site is: http://www.irelandecotours.com
    Thanks,
    Padre77;)
    #261117
    Hi padre77 !
    You fix it following way below :
    Open template_css.css file in templates/ja_antares/css folder , find following code section at about line 1003 :
    #ja-mainbody {
    float:left;
    width:80%;
    change to :
    #ja-mainbody {
    float:left;
    width:78%;
    padre77 Friend
    #261135
    Hello Hainn84,
    Thanks a lot for your help – that wored perfectly!
    Thanks,
    PAdre77
This topic contains 3 replies, has 2 voices, and was last updated by  padre77 16 years, 5 months ago.
