September 22, 2011 at 7:56 pm #168843
Hi, a couple of questions
1.- When I try to search in Google a comment, usually Google can´t find it. Google can find my articles very easy, but it is almost impossible to find comments. I wonder why
2.- If I´m lucky and Google find a comment, the result is very ugly, I mean, results are not like website template. I attach example. Result link is like this
Does it happen only to me, or is it normal?
Thanks a lot
jooservices Friendjooservices
- October 2014
- 1245 times in 1121 posts
September 24, 2011 at 1:18 am #414534Hi
It’s known issues.
Because JA Comment used ajax for display. And above your screenshot is ajax content return ( w/o any stylesheet ). And google crawled / cached this one.
We are working in next release to find out solution for this one 🙂
Thank you
Viet Vu1 user says Thank You to jooservices for this useful post
September 24, 2011 at 5:52 am #414590It´s great that you know the issue and then you can fix it. Component is great, but good results for Google are necessary.
Thanks a lot for your reply, and I´ll be waiting for next release
- October 2014
September 24, 2011 at 6:11 am #414595Hi
Thank you for your waiting .
I’ll respond you any update from dev team about this issue.
Thank you
Viet VuDecember 3, 2011 at 8:06 pm #427799Hi again
It is possible to know when it´s gonna fix the issue?
December 6, 2011 at 9:29 am #428190Please, I need to know if the bug is gonna be fixed soon just to know if I have to change component or not.
- October 2014
December 6, 2011 at 3:42 pm #428243Hi
#1. Our dev in working on this issue.
#2. Actually it’s not really bug. It’s just like missed features.Thank you
April 8, 2012 at 7:40 pm #447776Hi again after few months 🙂
Do version 2.5 fix that issue? I mean, will Google find my comments easily and without losing the template style?
AuthorPostsViewing 8 posts - 1 through 8 (of 8 total)This topic contains 8 replies, has 2 voices, and was last updated by dracoteam 12 years, 9 months ago.
Problems with JA Comment and Google plus ugly result
