  • ekaup Friend
    #189901
    Hello. I am trying to install modules or figure out how to create my site similar to the demo site. I have worked with many other templates, from Joomlart and others. This one (Ja Fixe) seem to be totally different animal.
    The module positions are totally different from what I am used to.
    Thetop menu (as in the Demo) doesn´t appear, even though I follow instructions.
    Is there any one that can help me or point out a detailed instruction.
    Please help.
    ekaup
    Phill Moderator
    #502914
    Have you seen the guides – http://joomlart.com/documentation/joomla-templates/ja-fixel-template.html . If they do not help the best option would be to install the quickstart and carefully compare each item with your own setup
    ekaup Friend
    #502916
    Thanks Phill, I have seen this before. I will try to reinstall the Quick start and take your advise. Thank you.
This topic contains 3 replies, has 2 voices, and was last updated by  ekaup 11 years, 4 months ago.
