maryorycuf Friend
maryorycuf
- February 2008
October 29, 2008 at 1:31 am #134874Hello good Night…
Problems with JA Kulanite in IE6 (transparent PNG images do not work). In IE8 is deconfigure page, the menu is moved to one side.
With IE6, transparent PNG images, is not working, you place a blue or gray box, which should see. And by modifying the file ie6.php, transparency works, but the menu does not work. not selected, nor is deployed. the menu will be selected lock.
In IE8, the page is deconfiguration. the menu, images, and icons, they move from place. moving to the left side. and looks bad.
In addition, to delete cookies in IE6, and update the page, the menu stops working, was not deployed.
And finally, the top menu, is limited in terms of space, to display the items. no moves until the width of the page. if there are many choices on the menu, places them below the first. as a second level.
I attached pictures to see the comments, which I have mentioned. I await your prompt response.
Thanks ….
- iamdbat Friend
iamdbat
- October 2008
November 1, 2008 at 2:29 pm #277705In IE8 set the compatibility mode to IE7
maryorycuf Friendmaryorycuf
- February 2008
November 5, 2008 at 9:33 pm #278206Thank you for the suggestion, but that does not solve my problem. Because of that, select the button, depending on the user. and if that does not know, not properly view the page.
In addition, in the images you can see, other errors. in other versions of IE.
Thanks ….
AuthorPostsViewing 3 posts - 1 through 3 (of 3 total)This topic contains 3 replies, has 2 voices, and was last updated by maryorycuf 16 years, 1 month ago.
