  • Sam Kanj Friend
    #135904
    Hi there,
    I am running joomla 1.5 where I have installed JA Teline. It was all running fine just like the demo site. My client happened to go in and try to add content himself. What he did was he copied text from word and pasted them in the article body. What that did, was through the right and left modules out of place making them fall under the JA news area. I corrected that when I adjusted one of the articles. Then all of a sudden the JA news stuffed up and just doesnt appear anymore in the way it appears on the demo site. I unistalled it, then reinstalled a newer version and all still gave me the same problem.
    the site is http://www.iraq2003.com
    anyones help is most appreciated as this site is doing my head in!!
    #281255
    Hi kanjart !
    You need must set ja news display with 2 columns , now it displays with 1 column. Please go to admin >> extensions >> module manager >> select ja news module, on right panel set to “2” columns.
    Sam Kanj Friend
    #281320
    Hi there,
    Thanks for the reply, but thats not it, there seems to be some sought of a bug issue, Ive done everything possible to find out why this has occurred.
    Sam Kanj Friend
    #281321
    You will notice that the module isnt working correctly. the headlines dont rotate, the news headings are gone. dont know what to do
This topic contains 4 replies, has 2 voices, and was last updated by  Sam Kanj 16 years ago.
