  • conquermedialtd Friend
    #143687
    I am having troubles installing JA Raite template on my site. I am not sure what am I doing wrong.
    while installing the quickstart files I get the following error at the admin panel-
    Error! Could not find a Joomla! XML setup file in the package.
    I can not see the slide show on the site also the front end gives me the following error:
    Warning: Invalid argument supplied for foreach() in /home/easyhote/public_html/templates/ja_raite/ja_menus/Base.class.php on line 62
    I am not sure what am I doing wrong but I feel if I have paid for the templates I should be able to use them smoothly without any troubles.can the moderators help?
    #315223
    i am also getting this erro while installing the quick start
    XML Parsing Error at 91:110. Error 4: not well-formed (invalid token)
    come on moderators .. help me out
    nefar Friend
    #315225
    Well I’m not sure what is the problem but I can tell you what I would do if it happend to me.
    1.) Wipe out the database.
    2.) Wipe out folder I installed joomla in
    3.) re-download the template
    4.) Run a phpinfo.php and or log into my host cpanel make sure everything is up to date. For example my host anytime you change an .htaccess file it reverts your php to 4 Which will screw up my joomla every time and tends to drive me up a **** wall.
    5.) Assuming everything is up to date I would upload the new quickstart.zip
    6.) Go into servers cpanel => file manager => unpack the quickstart file.
    7.) Go to website and re-install Joomla.— While I cross my fingers and hope I don’t see any funky errors again.
    #315226
    My DB has about 60K pages. To wipe out DB I will have to thnk a million times mate.
    nefar Friend
    #315227
    Well I’m not saying wipe out all your database, just the dabase you created for Joomla install.
    #315228
    <em>@nefar 141902 wrote:</em><blockquote>
    QUOTE]
    which folder should i upload quickstart.zip?
    #315230
    the data is integrated inside joomla tables. so can not wipe it out. where do i upload quickstart. is it undert jaraite template folder or any other location
    nefar Friend
    #315240
    If you are just installing this now it should be no issue to delete the database you created for joomla. If you mean that you installed joomla to an exisiting database instead of it’s own then yes, it would be more of a pain to remove it. Though I’m sure someone has a drop table script out there just for Joomla.
    As for the file, once you have downloaded ja_raite_for_joomla_1.5x.V1.0 you would unpack that on PC and then browse to the quickstart folder. Here you will find qs_j1514_ja_raite.zip This is the file you will upload to your server.
    Where you “unpack” it on your server is up to you… If you use a subfolder, domain.com/test/ then you would unpack it in the test subfolder. If you want it installed direct to your main domain it’s going to depend on your setup. For instance if you have a host with multiple domains it might be public_html/domain_name Or if you only have 1 domain it will go into /public_html/
    #315690
    The question was which folder of Joomla ? Does it have to be under templates?
    #315691
    Its Giving me the following error –
    Slideshow
    Warning: opendir(/home/easyhote/public_html/templates/ja_villadi/images/header) [function.opendir]: failed to open dir: No such file or directory in /home/easyhote/public_html/modules/mod_ja_header/mod_ja_header.php on line 37
    Warning: readdir(): supplied argument is not a valid Directory resource in /home/easyhote/public_html/modules/mod_ja_header/mod_ja_header.php on line 41
    The moderaters or the tech support doesnt answer emails? Are we gonna get A solution?
    chasewseo Friend
    #341950
    did you guys get this figured out?
    pwdubai Friend
    #354099
    I too had issues with the installation of the template but now all is well and running fine.
    However, I have had a problem for a while now but still cannot work out what to do.
    Basically,
    With this template every page has the H1 tag as the logo as below:
    <!– HEADER –>
    <div id=”ja-header” class=”wrap”>
    <div class=”main clearfix”>
    <h1 class=”logo”><a href=”/index.php” title=”Property World Dubai”>Property World Dubai</a></h1>
    </div>
    </div>
    <!– //HEADER –>
    What I want to do is use “normal” H1 tags so that I can make them different on each page rather than the above. IE if I am writing an article then I can add 1 H1 on that page saying “Dubai Property” etc etc
    So I need to find out a way to get rid of this h1-logo that is automatically generated on every page.
    All advise is appreciated..
    John
This topic contains 12 replies, has 4 voices, and was last updated by  pwdubai 14 years, 2 months ago.
