  • thatch10 Friend
    #174475
    I have a problem with I.e 9 and I.e when using the JA Rave Template. This has caused me to seek updates to the template.
    I am using joomla 1.5.25 with this template which was originally installed from the quickstart.
    I have changed logo etc, however in i.e when I attempt to add an event using the jcal pro component the logo is replaced by the original JA Rave template settings adding the red line under the menu and the JA Rave Logo.
    I sought an upgrade from the JA Extensions manager
    This tells me that there are two versions of the template available to upgrade to, 1.1.0 and 1.0.0 beta.
    When I attempt to upgrade to the 1.1.0 version my template disappears from the admin menu options, however the site still appears to display with the jarave template, no other default option is visible in the backend.
    I thought that I would upgrade the template manually so downloaded the latest version of the template. This contains version 1.0.2 which is the version that I have and is causing me the i.e issues.
    When I use the JA version checker online their are two versions of the JARave template in the list. Is this what is causing the confusion in JA Extensions manager.
    Can someone please confirm which version of the template is the latest version that I can use with j1.5 and let me know where to download it from.
    I.e is causing issues with the template display and the use of the jce template. I changed the template which allows the editor to display properly.
    I think my display problem is one of two issues, either template or module induced.
    1. jarave
    Manos Moderator
    #441338
    I have informed our developers for this issue since it appears that there is a problem probably in the xml file so they will be working on it assap
    Manos Moderator
    #442232
    It appears that your problem is solved?
This topic contains 3 replies, has 2 voices, and was last updated by  Manos 12 years, 9 months ago.
