  • id31 Friend
    #147542
    I have a problem with the JA Sulfur Template, the Slideshow (Header) with Modul JA Slideshow 2 does not works.
    Position its ok: ja-slideshow
    Path for images is also ok: images/stories/header/
    Picturen will be there, but it does works?
    Please help me…!
    Best Regards from Germany
    Hello guy!
    Please try to configuration the value for all parameters same as our demo did. I recommened you should named for images to be lowercase and without space.
    If the problem does not fix, please give me the link to the live site.
    fortza Friend
    #329882
    Hi.
    I have the same problem, and I canĀ“t see the pic. in your user guide……so i cant solve it that way……….
    http://www.viris.dk
    Best, Fortza
    Hello guy!
    I checked your site, the site seem to work well. may be you fix this ?
This topic contains 4 replies, has 3 voices, and was last updated by  Saguaros 14 years, 12 months ago.
