  • losttransmission Friend
    #692551
    I am having problems with JA Slideshow being responsive and showing up on mobile devices, it is fine on desktop and tablets. Does anyone know how I can change the settings to enable it to show up on mobile devices?
    Note: I am a novice on site building, don’t understand code and only have experience in simple Joomla actions, so please be as simplistic as possible … if possible!!
    Thanks on any help in advance!!
    Pankaj Sharma Moderator
    #692592
    To show slideshow in small device
    go to templatepurity_iiitplsblocksslideshow.php
    Find this code
    <div class="slideshow hidden-xs <?php $this->_c('slideshow') ?>">
    Replace it with
    <div class="slideshow <?php $this->_c('slideshow') ?>">
    Path: /templates/your JA templates/css/custom.css
    if File is not there create it .
    + Add this code in custom.css file to adjust the slideshow height in mobile view
    @media (max-width:468px){.ja-ss-item
    {min-height: 100%!important; padding:0px!important} }
    #749749
    Find this code
    Replace it with
    #692827
    Thanks very much – I was able to find the code for the first part no problem and I can see why the height needs adjusted!
    However to adjust it I cant find the path to get to /templates/your JA templates …. should there be a “your JA templates” folder in the template section? Or is it somewhere within the Purity iii template files?
    Sorry if i’m being silly here, i’m learning as I go along!!
    #749765
    #692828
    One more problem if anyone can help please. I am using JA Slideshow to display the above image on some of my pages. How can I remove the unused space that I have highlighted in green? Is there a simple way to do this?
    Thanks in advance for any advice or help I can get on this!
    #749766
    arthurjohnston Friend
    #692841
    <em>@losttransmission 494213 wrote:</em><blockquote>Thanks very much – I was able to find the code for the first part no problem and I can see why the height needs adjusted!
    Sorry if i’m being silly here, i’m learning as I go along!!</blockquote>
    Replace “your JA templates” folder with the folder name of the template you are editing. ie: /templates/Purity_iii.
    I hope that helps.
    #749779
    I hope that helps.
    #693144
    <blockquote>Replace “your JA templates” folder with the folder name of the template you are editing. ie: /templates/Purity_iii.
    </blockquote>
    as said above Your JA Template refer to the Joomlart template on your site , Its Purity III . Create custom.css and add the suggestion code .
    #749832
    </blockquote>
    #693415
    Thanks very much for the replies! I managed to get it to work!
    #749959
This topic contains 13 replies, has 3 voices, and was last updated by  losttransmission 9 years, 3 months ago.
