  • Tech-xml Friend
    #159379
    Problems with JAcomments
    1 – I made the integration with the K2 JAcomments
    2 – K2 manager deativei comments.
    The problem is that the comment block is coming up the block tags of K2. I changed to other position in the Plugin settings JA comments, but did not function.
    I need the feedback block is displayed below the entire contents.
    nghiatd Friend
    #374052
    In order to diagnose the issue further, please provide us with your site admin access, FTP access information by updating in this ticket.
    http://support.joomlart.com/index.php?/Tickets/Ticket/View/62560/-1/-1/-1
    For information on best security practices, and frequently asked questions about sharing access with JoomlArt support, kindly refer to the knowledgebase article at: http://support.joomlart.com/index.php?/Knowledgebase/Article/View/3/0/providing-joomlart-with-access-to-your-site-or-server
    Best Regards.
    Tech-xml Friend
    #374153
    I updated the Ticket
    nghiatd Friend
    #374178
    Please turn on plugin content jacomment then select ENABLE THE PLUGIN FOR : k2.
    You can turn off plugin system jacomment if you only want to use jacomment for com_content and com_k2.
    Best Regards.
    Tech-xml Friend
    #374246
    The problem continues.
    The block is above the comment block TAGS
    nghiatd Friend
    #374801
    I can’t load your site because it appeared with error:
    Warning: file_put_contents() [function.file-put-contents]
    Warning: Unexpected character in input: ”’ (ASCII=39) state=1
    Parse error: syntax error, unexpected $end
    when you done with your site please tell me.
This topic contains 6 replies, has 2 voices, and was last updated by  nghiatd 13 years, 11 months ago.
