  • hostcomdo Friend
    #137952
    I bought a template with this extension (javmproductslide). Now im trying to use it on my page and it is not working.
    I installed it properly, and, in the administrator panel it looks to work fine, but in the public area, when i activate the module, it give me an error, and my web doesn’t show up!
    My web page begin again to work when i deactivate the module.
    THIS IS THE ERROR:
    Warning: require_once(/administrator/components/com_virtuemart/global.php) [function.require-once]: failed to open stream: No such file or directory in /home/encuentr/public_html/site/components/com_virtuemart/virtuemart_parser.php on line 74
    Fatal error: require_once() [function.require]: Failed opening required ‘/administrator/components/com_virtuemart/global.php’ (include_path=’.:/usr/lib/php:/usr/local/lib/php’) in /home/encuentr/public_html/site/components/com_virtuemart/virtuemart_parser.php on line 74
    I tried to install in other web too and it give me the same error!!!! IN OTHER JOOMLA 1.5x sistem!
    Could anybody help me!
    jsliao Friend
    #290360
    first. where did you buy the template from. no one is licensed to resell JA products i believe so i doubt anyone will give you any support here when you are an unlicensed member.
    hostcomdo Friend
    #290446
    i bought this template here….
    like a month ago, and now im using it.
    It came with the Ja_larix template.
    ¿Do you think i would ask for help if i dont think i deserve it?
    I pay for use your services and its not working :(:(:(
    I just try it in other web to see if i had the joomla properly installed,and in both it doesnt work!!
    jsliao Friend
    #290472
    i do not represent joomlart. i’ll leave it to the admin to help you then.
    cheers
    hostcomdo Friend
    #290498
    Thanks.
    How could i contact Joomlart´s administration?
This topic contains 5 replies, has 2 voices, and was last updated by  hostcomdo 15 years, 9 months ago.
