maghen Friend
maghen
- May 2007
- 3 times in 1 posts
May 28, 2008 at 4:27 pm #129001Anyone who – successfully – has installed “Joomla Tags For Joomla 1.5.x” (from Phil Taylor/Blue Flame) in a JA Teline II site?
I would like to know what adjustments to make so this otherwise brilliant component doesn’t break the template. (The two right columns are forced downwards when I install the addon which provides tagging interface in content).
I’m using JA Teline II v1.2 and Joomla! 1.5.3.Anyone?
Menalto FriendMenalto
- May 2007
- 531 times in 361 posts
May 28, 2008 at 7:47 pm #250932Whats your site url?
And please give an url to where the problem ismaghen Friendmaghen
- May 2007
May 28, 2008 at 9:05 pm #250944I’m setting up the site offline on xampp (http://localhost), but have now duplicated the installation on a demo site: http://balkongen.net/balkongen/index.php
There you’ll see that in article view, the two right columns drop down under the article.
when the addon that show tags under each article, is activated.
Deactivating this addon, eliminate the problem – but, then, again, it’s rather pointless, I think, to have tags without displaying them under each article.I could give you access to the admin panel etc. if you’ve got a secure channel for transmitting these data.
- May 2007
May 28, 2008 at 9:42 pm #250949Just give me a PM with the log in info and ill check it out. If you have FTP access i would like that too.
maghen Friendmaghen
- May 2007
May 28, 2008 at 10:06 pm #250950Thanks. It’s done.
Omar Ramos JAECOmar Ramos
- 15 times in 1 posts
May 28, 2008 at 11:40 pm #250960I’ve localized the problem to this line of html:
<div class="clearfix" id="ja-container-inner">
The class=”clearfix” part is what is causing the problem…let me find out where it’s coming from and I’ll get back to you in just a minute.
May 29, 2008 at 12:00 am #250966OK, it’s on line 157 of the template’s PHP file.
JOOMLA_ROOT/templates/ja_teline_ii/index.php:
<div id="ja-container-inner" class="clearfix">
What I don’t know yet is if this class is is required for the other pages?
If it is then it wouldn’t be wise to completely remove it, but maybe on article pages it would be ok to not have it.
In that case I would replace the line of code above with:
<?php if ((JRequest::getVar('option') == 'com_content') and (JRequest::getVar('view') == 'article')): ?>
<?php else: ?>
class="clearfix">
<?php endif; ?>That would add a check to see if a visitor was on an article page or not…if so then class=”clearfix” part won’t get shown.
Hope that helps :-).
maghen Friendmaghen
- May 2007
May 29, 2008 at 12:21 am #250967Absolutely brilliant! Thank you very much! You really made my day. I’could never have solved this by myself – even my dog finds me totally incompetent when it comes to php – and hides when I open such files..
So far I haven’t seen any problems with your solution. Any of the template creators who have a point of view -?
This topic contains 8 replies, has 3 voices, and was last updated by maghen 16 years, 7 months ago.
