  • melquiades Friend
    #190001
    Using the k2 i always get this message
    Strict Standards: Declaration of JParameter::loadSetupFile() should be compatible with JRegistry::loadSetupFile() in /home/municipi/public_html/libraries/joomla/html/parameter.php on line 512
    what should i do?
    HI melquiades,
    It appears to be issue of K2 with Joomla, try going to to backend > Global Configuration and set Error Reporting to No
    melquiades Friend
    #503449
    Done, the matter is that in this way i can’t use most of the K2 features (content, tags…)…
    Which version of Joomla and K2 are you using? Could you tell me more details about problem of using these K2 features in your site?
This topic contains 4 replies, has 2 voices, and was last updated by  Saguaros 11 years, 4 months ago.
