fmolina Friend
fmolina
- August 2013
February 24, 2014 at 7:22 pm #195165I have a problem with k2
When I use an image using the tab appears k2 item is not me. There is a conflict that goes broken.
You can see in the picture what happens after you load the image.
I tried to do it from the media manager of joomla and k2 and the same thing happens.thank you very much
Saguaros ModeratorSaguaros
February 25, 2014 at 3:58 am #524210If the issue happens in both media manager of Joomla and K2, then pls try to disable any 3rd party extensions installed in your site. In case that problem still persists, you may consider to update K2 or Joomla to a newer verion (remember to BACKUP your site first)
AuthorPostsViewing 2 posts - 1 through 2 (of 2 total)This topic contains 2 replies, has 2 voices, and was last updated by Saguaros 10 years, 10 months ago.
Problems with k2
