  • limengming Friend
    #116916
    Left column position out when browser’s window resized, after refresh it goes back to normal.
    And why the copyright logo is not showing but instead with ?.
    Have a look at http://host.101portal.com.
    Any Idea, please help?
    Hieu Nguyen Admin
    #209906
    I just used IE6, and Firefox 1.0.6 to browse your site, everything seemed to be fine when I resize the browser’s window. Which browser are you using, limengming?
    limengming Friend
    #209917
    I am using IE v6.0.2900.2180.xpsp_sp2_gdr.050301-1519.
    Herewith I attached two screenshoots for your reference.
    However I managed to tweak the “template_css.css” on #leftcol by removing
    line “position: relative;” and it worked fine. But I’m not sure it is a correct way.
    By the way, how do I show the © (copyright sign) on footer. It was OK when using
    default Joomla Template.
    Thanks and regards.
    1. after_resized
    2. after_refreshed
    Hieu Nguyen Admin
    #209952
    It’s ok, limengming, you can remove “position: realative;” and the bugs are solved. BTW, please apply the hack for JA Archenar here http://id.joomlart.com/forums/topic/updated-files-for-ja-archenar/, it also contain a lot of minnor bugs fix for the template.
    You can use
    for the © copyright sign. I’m sorry for using the wrong copyright char in JA Archenar footer.
This topic contains 4 replies, has 2 voices, and was last updated by  Hieu Nguyen 18 years, 5 months ago.
