  • natali523 Friend
    #128948
    When I introduce data access module login said:
    “not have permission to access this section”
    I have reviewed the configuration and everything’s OK. Where is the problem? I need urgent help.
    This is the template that has given me more problems. >:(
    natali523 Friend
    #250727
    moreover, I had to manually modify the code to change the width of the template, and now can not remove a green line that appears. I can not find the file. Can anyone tell me where can I delete it?
    http://www.antiguedadesgil.com/web/
    I do not know if understand my English. Do not speak English, I do so through a translator. :-[ :((
    #252061
    Hi natali523 !
    Sorry for delay !
    About remove greenline You must edit mainwrap-center.gif image in templates/ja_koniga/images folder. In this image there is a green dot.
    natali523 Friend
    #252127
    OK. Thank you very much. Can you tell me how to resolve the problem with login module? I tried many things and no longer has worked me. This is the first time I see that in joomla.
    I need to deliver this site tomorrow, the customer is waiting. I would appreciate help as soon as possible please. 😉
    natali523 Friend
    #252171
    I have solved the problem. 🙂
    the index.php file was corrupted, I only had to replace it.
    Thanks :):)
This topic contains 5 replies, has 2 voices, and was last updated by  natali523 16 years, 6 months ago.
