  • marturo Friend
    #165303
    I’ve used the MegaMenu to display two modules.
    If I use ony one it works fine, but if i use one other modules both menu items show the same content (even if they are set to two different modules)…
    Have you an idea to solve it?
    Thanks!
    Marturo
    pritam Friend
    #396831
    Hello marturo,
    Can you provide the site url and admin access so that we can help you better.
    marturo Friend
    #397147
    Hi Pritam,
    I’ve sent you a Private Message…
    pritam Friend
    #397624
    Hello marturo ,
    I have checked your site . Its looking and working fine . If the issue has solved than we can close the ticket . Otherwise send the screenshot where you getting the problem.
    marturo Friend
    #397659
    <em>@pritam 248636 wrote:</em><blockquote>Hello marturo ,
    I have checked your site . Its looking and working fine . If the issue has solved than we can close the ticket . Otherwise send the screenshot where you getting the problem.</blockquote>
    Please, check the site now: if you pass on AUTORE and FINALITA’ in MegaMenu, there is the same content (with diiferent modules)…why?
    Thanks again
    pritam Friend
    #397863
    Hello marturo ,
    I have check your site and admin for MegaMenu . You need to check AUTORE in Megamenu . You can goto admin login->Menus -> Main Menu* -> AUTORE ->Menu Item Type * . Here you can Select a Menu Item Type for Your menu AUTORE . You can get different parameters to set menu .
    marturo Friend
    #397981
    Hi Pritam,
    thanks for the answer: your procedure is clear, but…i’m not able to solve the problem.
    I did these steps: Main Menu > AUTORE > Menu Item Type, then Paramets (JA Extended) > Submenu content >Modules>AUTORE. And again Main Menu > FINALITA’ > Menu Item Type, then Paramets (JA Extended) > Submenu content >Modules>FINALITA’
    How can you control the selected modules are different, but in front page the slide of MegaMenu is the same and not different…:confused:
This topic contains 7 replies, has 2 voices, and was last updated by  marturo 13 years, 6 months ago.
