  • monalh Friend
    #181399
    Hi!
    I hav recently started using Vinaora Nivo slider on my web http://www.wayosi.no, but suddently I see that the drop-down menu does not work/show when the Novo slider module is active. The drop down menu does not show when hover on the page the module is active, but works on pages were the module is inactive.
    I have used JA Slide show module up until now, but I have had problems that only 16 of 20 photos added to the slideshow-folder shows, so I decided to try another module. But I like the Nivo-slider, so would be very happy to get some input on what could be wrong..
    Ninja Lead Moderator
    #469969
    Yeah, I detected out the problem on your site. The reasone is Vinaora Nivo slider module is conflicted with jQuery and Mootools. Let me help you to get this fixed. This is the solution:
    <blockquote>Open modules/mod_vt_nivo_slider/mod_vt_nivo_slider.php file</blockquote>
    find
    JHtml::script('media/mod_vt_nivo_slider/js/jquery.nivo.slider.min.js');
    and add new script
    $document = JFactory::getDocument();
    $document->addScriptDeclaration('jQuery.noConflict();');
    Please check it again let me know if the problem on your site still persists.
    monalh Friend
    #469989
    Yes! Thank you, that worked like a charm! 🙂
This topic contains 3 replies, has 2 voices, and was last updated by  monalh 12 years, 2 months ago.
