  • ratax Friend
    #188848
    my site use JA University and I also use “Accordion FAQ” plugin to make accordion effect inside an article.
    When I open an article that contains my Accordion FAQ’s, the sub-menu items of that menu (and others’) don’t scroll down.
    Here are the screenshots :
    http://www.hostingpics.net/viewer.php?id=591912SubMenuproblem.png
    Then when “Include jQuery script” parameter is set to “No”, the other menu and sub-menu items (both here for “Recherche” and “Formations”) scroll down BUT the text with Accordion FAQ has disappeared.
    Is that a problem due to jQuery ?
    How could I solve this ? I’m a beginner in creating websites and don’t really know what kind of code I should check.
    Thank you in advance
    phong nam Friend
    #498696
    Hi ratax,
    When you enable the Accordion FAQ module with Include jQuery script, you also need to select the article you want to display this module (Basic Options >> Article box). Lets see my attached image & clear JAT3 cache after saving change.
    1. 7-11-2013-4-57-32-PM
    ratax Friend
    #498737
    Hi Leo,
    I think we don’t use the same version of Accordion FAQ because I dont have this Article box.
    Here is how my parameters page looks like :
    I’m using “Joomla 2.5 plg_AccordionFAQ 2.5.8”.
    I’m using the plugin version as I can easily customize the accordion effect for each article I edit.
    What version of Accordion FAQ do you use ? Should I download it ?
    Thank you in advance,
    ratax
    1. AccordionFAQ_parameters
    phong nam Friend
    #498739
    Hi ratax,
    I mentioned about Accordion FAQ module 2.5.8 which you can configure the Article option in the backend. Currently, there is a js conflict between Accordion plugin and our JAT3 plugin . As you know, changing the js functions of 3rd party extension is not under our support service.
    The solution: You can try on Accordion FAQ module on menu item (Single Article type) instead of putting {accordionfaq …..} in the article content. It will works fine when you configure the module like my snapshot above.
    ratax Friend
    #498748
    Hi Leo,
    Thank you for your response. I thought that there were a way to solve my problem with Accordion plugin, as I just want to put it into an article, not to have menus besides.
    I managed to try the AccordionFAQ module as you said. Thank you very much for your help I think it will be very useful in the future.
    However I have found another solution with Core Design Accordion plugin, which enables the accordion effect inside an article content.
    This is really what I wanted to have :
    My goal was to simplify the editing process (here we don’t have to configure the module for each page) as there are many articles to do like that.
    It’s just because I am creating the website now.. but people in charge of it in the future may have a little less competences in website programming.
    Anyway, thank you very much. Hope the js conflict between Accordion plugin and JAT3 plugin will be solved soon.
    Regards,
    ratax
    1. AccordionFAQ_module
    2. CoreDesignAccordion_plugin
    phong nam Friend
    #498756
    Hi ratax,
    Nice tip you have. Thank your for sharing 😉
This topic contains 6 replies, has 2 voices, and was last updated by  phong nam 11 years, 4 months ago.
