  • fbernardello Friend
    #832964
    Dear Support,
    I have some problems with mobile layout:
    1. My texts, in JACM are cutted (see attached image 1.jpg). This is for sure my fault, because I increased the font dimesion, but I don’t know how to fix it.
    2. While the images in JACM ser with "Featured News:style1" are perfect, the images in JACM set with "Category Listing:style-1" are cutted (see attached image 2.jpg)
    3. This issue is based on a solution I found in the forum (here: https://www.joomlart.com/forums/topic/hide-one-module-in-mobile/). If I define this rule:
        .mobile_hide {display:none;}
    And I set it on a module suffix, the module disappears from any layout.
    How can I set in my custom.css this rule to be applyed only to small and extra-small layouts?
    I would like to hide banner-1 position from these layouts (I think it’s visible because of a tip).
    Best regards,
    Federico
    1. 14
    2. 2
    fbernardello Friend
    #832947
    Dear support,
    And I set it on a module suffix, it disappears from any layout!
    Regards,
    Federico
    P.S. No more Search on new forum? 🙁
    Pankaj Sharma Moderator
    #833709
    Hi You can add this rule in custom.css
    @media and (max-width: 768px) { .mobile_hide {display:none;} }
    It will work below the width 768px only . Hope it helps
    or simple add
    hidden-xs
    with a single space in module options > module suffix . save and check this will hide module in extra small layouts .
    fbernardello Friend
    #833822
    Hi @pankaj,
    thank you for you reply. I was using "hidden-sm" to hide some modules in tablet layout and it works.
    I would like to hide both in smartphone and tablet.
    I tryed with the code (I disabled the cache), but it’s not working…
    Federico
    #833839
    use hidden-xs
    to hide it in small layouts . Share your Module ID that u want to hide and the site admin details via private reply i will check it .
    fbernardello Friend
    #833844
    Hi @pankaj,
    I see, but I would like to hide the modules both on sm and xs layouts.
    I’m sending a private reply with my credentials.
    Thanks,
    Federico
    fbernardello Friend
    #833845
    #833847
    Could u provide the module ID that u want to hide and not working at this time .
    I did not found it in your last post.
    fbernardello Friend
    #833848
    Hi @pankaj,
    I’m sorry, you’re right! Module ID 240.
    Thanks,
    Federico
    #833864
    i added hidden-xs in module options > http://prntscr.com/9js1xs
    kindly clean cache and check , module is not showing in mobile .
    hidden-xs for extra small .
    hidden-md for medium size .
    fbernardello Friend
    #833866
    Hi @pankaj,
    thanks a lot! I thought it was not possible to set more than 1 suffix to a single module. Very good!
    Would you be so kind to help me with the other two points (text cutted and images)?
    Thanks in advance,
    Federico
    #833872
    Add this code in custom.css file for images and
    .magazine-leading .magazine-item-main .magazine-item-ct {
        max-height: 160px!important;
    .magazine-featured .item-image, .magazine-categories .item-image {
        max-height: 100%!important;
    it will solve the problem .
    for text if it still hide increase the 160px value of height in above code
    fbernardello Friend
    #833887
    Hi @pankaj, great: the code solves both the problems!
    Thank you very much for your precious help.
    Happy new year!
    Federico
This topic contains 12 replies, has 2 voices, and was last updated by  fbernardello 9 years ago.
