ferdilebu Friend
ferdilebu
- July 2013
July 22, 2013 at 3:41 pm #189150Hi I have two problems to solve in my shop
When placed the mod_javmproducts Module on home-1. Those white boxes are shown above and below me the module .That are unsightly. I urgently need to get them out of that place.
In which file and which part should I edit the css style?
Please like 3 days ago postulating this problem but I followed the thread.
And the other problem is YOU_HAVE_NO_ITEMS_IN_YOUR_CART How do I change those words?
Both problems can be viewed on the photo.
phong nam Friendphong nam
- May 2015
- 974 times in 888 posts
July 23, 2013 at 4:27 am #499856Hi ferdilebu,
The white boxes can be caused by the plugin displaying in the content area. I can’t find out which name of that plugin is, because your website blocked the access to admin url. But you can hide these white boxes by adding below css codes into templates/ja_hawkstore/css/custom.css file on your server:
section.tab-products div.custom code {
display: none !important;
}The template language files for Espanol language are not included in our JA Hawkstore template . You can solve this issue by putting my attached language file to languagees-ES . Then find line:
YOU_HAVE_NO_ITEMS_IN_YOUR_CART="You have no items in your shopping cart."
You can change the red line with your Espanol.
Note: You can copy and rename the English language files of our template in en-GB folder to es-ES if there are any language errors on other modules/areas. That will solve the missing language files on your website.
ferdilebu Friendferdilebu
- July 2013
July 25, 2013 at 3:18 pm #500154I could not translate it! I modified the folder both English and Spanish and there is no solution.
also I have a serious problem that can not add products to cart.
Urgent need for a solution because every day we sell products.
Please I need your help.
- July 2013
July 25, 2013 at 3:20 pm #500155From which country do you work??
because I have to talk to my server because I do not understand for what reason the administration is blocked.
- May 2015
July 26, 2013 at 1:44 am #500176Hi ferdilebu,
I has sent you PM with my IPs address this earlier morning. If possible, can you try to add my IPs address to white list for accessing the backend url ?
On language text translation issue, You should copy the language files of en-GB folder to es-ES folder, you can translate the texts then. I saw you translated to the es-ES texts successfully on your website. Do you still need our help on this concern ?
- July 2013
July 26, 2013 at 7:30 am #500200You can not guide me for me to find the error? The server blocks me your country and engineers have told me that the answer will be given next week is too late! I have 10 clients who want to buy in my shopping.
Can not you see the error via FTP? please give me a solution today.
What plugins should I monitor? ?
- May 2015
July 26, 2013 at 1:13 pm #500236Hi ferdilebu,
I has gotten your PM with the website’s credentials. Well, as you know that your issue is related to the customization changes on our template, so that i need some time to check & back to you with detailed solution then. I hope you can wait for me !
- July 2013
July 26, 2013 at 3:54 pm #500252ok I’ll be waiting! anything you write me, thanks!
think you that today will be solved? this weekend I enable compulsory shopping, I’ll have to take everything apart and rebuild ja_kranos, a total penalty,
hopefully the problem is solved.
- July 2013
July 28, 2013 at 9:57 pm #500381wait two days for me was too much, so now is the issue resolved. The only remaining problem is that the cart does not work in modal popup, I should update you browser to see the new products. I think it’s a template error. I did not find the solution.
- May 2015
July 30, 2013 at 5:10 am #500552Hi ferdilebu,
Please keep calm. You raised the same issue on many threads so that it is hard for us to follow these. See my reply at http://www.joomlart.com/forums/topic/the-product-number-not-updated-in-cart/
AuthorPostsViewing 10 posts - 1 through 10 (of 10 total)This topic contains 10 replies, has 2 voices, and was last updated by phong nam 11 years, 5 months ago.
problems with mod_javmproducts Module and add cart
