  • OriolS Friend
    #894675
    I have some problems with your template when trying to add a module class suffix.
    The class suffix does not appear on the code.
    It happens when is a slideshow of the Advanced Custom module.
    1. Captura01
    2. Captura02
    Pankaj Sharma Moderator
    #894687
    Acm slideshow loads style only from php style files . You can add custom class directly in the
    templates/ja_elicyon/acm/slideshow/tmpl/style-owl.php
    Or make the module style to xhtml from module advance options > Module style > http://prntscr.com/ab0xnn
    save and check .
    OriolS Friend
    #894702
    Thanks the second option works perfectly.
This topic contains 2 replies, has 2 voices, and was last updated by  OriolS 8 years, 9 months ago.
