fmolina Friend
fmolina
- August 2013
March 2, 2016 at 2:00 pm #893462Hi.
I have problems with the text style in this module (see image). No is possible the original (simil to demo) text styles for this modules.Can you help me?
pavit Moderatorpavit
March 2, 2016 at 5:10 pm #893580Hi there
Could you share as private reply a temp super user account to your backend ? in this way we can better help you to solve this problem
fmolina Friendfmolina
- August 2013
March 2, 2016 at 5:46 pm #893603This reply has been marked as private.pavit Moderatorpavit
March 2, 2016 at 6:26 pm #893622fmolina Friendfmolina
- August 2013
March 3, 2016 at 11:11 am #894177This reply has been marked as private.pavit Moderatorpavit
March 3, 2016 at 5:59 pm #894413Hi there
Could you first update your template version to the 1.1.2 release ?
Take a backup first to update it
- August 2013
March 8, 2016 at 9:26 am #896521Hi. I updater to the new version.
Can you test please?Other question:
How I can updater joomla project extensions from JA extensions manager?
I need a user and password?pavit Moderatorpavit
March 8, 2016 at 9:53 am #896523Hi
You missed to include into the tag your text it should be in this way
<p><a class="btn-icon btn-big icon-contact" title="Contáctanos" href="index.php/contact"><span>Contáctanos</span></a></p>
I corrected it and now they are showing correctly .
I need a user and password?Yes you should add into Service manager your Joomlart account and set that service as the default service
Best regards
- August 2013
March 8, 2016 at 10:03 am #896525Thanks a lot.
How I can connect JA Extensions manager with Joomla Proyect for updater Joomla project extensions?
March 8, 2016 at 10:10 am #896527How I can connect JA Extensions manager with Joomla Proyect for updater Joomla project extensions?
I looked at it and set Joomlart update as the default service , it is working fine now .
- August 2013
March 8, 2016 at 10:18 am #896529Yes. sorry for my english. Not is good.
I can updater joomlart extensions but I want update Joomla Proyect extensions.Thanks
March 8, 2016 at 10:31 am #896552but I want update Joomla Proyect extensions.
Ja extension Manager support only updates for Joomlart Extensions you cannot use it for other Joomla projects, for that extensions you should use the default Joomla extension manager.
AuthorPostsViewing 12 posts - 1 through 12 (of 12 total)This topic contains 11 replies, has 2 voices, and was last updated by pavit 8 years, 9 months ago.
