  • kauepbd Friend
    #171074
    I bought the template JA Blaze recently and during installation (quickstart mode) I chose to install the content “Demo content”, that includes several posts and all modules and plugins already enabled and running.
    But I’ve been facing the following problems:
    – Lapse between the time that I publish the post and when it appears in Home. Usually, I write and save it in one day and it just comes to be published in another. I just set the “Server Time Zone” (I am testing everything on a local server Wamp) to my local time, but until now it had no effect, the posts are still not showing.
    – Most of the modules has the same lapse. The twitter module doesn’t show my latest tweets, I can’t get the module, and any other, “Latest News” display the category items I want to. Things like this, all configuration I try to do only appears on the next day or worse, nothing changes.
    Thanks for any help.
    TomC Moderator
    #426485
    Are you making sure to clear your JAT3 cache as well as your browser cache when making changes?
    kauepbd Friend
    #426525
    No, I didn’t do it.
    How do?
    And another thing, every time when i will post i need do this?
    TomC Moderator
    #426594
    You can clear your JAT3 cache within your site administration – the link/button is within the upper right navigation list.
    Each browser has a different way to clear it’s cache – so you will need to research how to clear your particular browser’s cache
    (which you can find very easily via a simple Google search).
    kauepbd Friend
    #426617
    Ok, it worked, the posts and changes to modules appeared.
    But for that to happen, I always have to click Clear Cache panel Joomla.
    You must do this ever?
    Well, the Twitter module is still not showing my recent tweets
    TomC Moderator
    #426651
    If you are experiencing issues such as the one you experienced above, then clearing your cache(s) is one of the first troubleshooting steps you should take to see if this might be an issue. Perhaps you can configure your browser’s cache settings so that it clears/cleans itself out every so often.
    Glad the suggestion worked. All the best with your continuing web development.
    kauepbd Friend
    #426963
    Ok, thanks for you help.
This topic contains 7 replies, has 2 voices, and was last updated by  kauepbd 13 years ago.
