  • neli Friend
    #147374
    Hi to everyone.
    I just installed ja telline 3 and i got a lot for problems..i have followed all tha instructions tha i found at usergudie but my site is not working propertly.
    For excample frontpage is not working as it should..in a lot of articles my pictures are very big and the articles are not shown as they should.
    Look here to understand what i am talking about http://www.albanians.gr/misioni-jone.html
    At this link my pic..is tooo big and tha article is not shown as it should.
    Also i have configured my frontpage to show all tha sections..but is ist not doing that ..instead of that its showin my this.. http://www.albanians.gr/
    Finally i would like to change MY FONTS..where can i do that?
    If there is a guide to make my site to llok excatly as it looks at live demo i would like to see it.
    Than you in advance and sory if i tired you 😉
    micrantha Friend
    #328489
    Helo neli,
    You are far away from setup of demo…..
    To begin with: I think you didn’t activate any module: Ja-frontpage and JaNews2 on Demo frontpage are modules; tab-navigations on right side are modules. First try to configure these.
    Images are resized when all is configured well.
    Good luck,
    Micrantha
    bennitos Friend
    #328493
    It might be a better idea to start with a quickstart on a different location and then put your articles in.
    Teline is a hard template to start with.
    neli Friend
    #328494
    <em>@micrantha 159329 wrote:</em><blockquote>Helo neli,
    Good luck,
    Micrantha</blockquote>
    Micrantha Thank you for your respond.
    I had installed all the modules but they wernt working as they should..so i unistaled them and i installed them again..i am tryin still to make it work propertly..
    neli Friend
    #328495
    <em>@bennitos 159333 wrote:</em><blockquote>It might be a better idea to start with a quickstart on a different location and then put your articles in.
    Teline is a hard template to start with.</blockquote>
    I am using joomla for more than 2 years now.
    These site have articles from 2007 until now..how can u make it possible to move all the articles on a diffrent location and to use this template? Could you please tell me the way?…
    Thank you
    micrantha Friend
    #328538
    Hello neli,
    As bennitos wrote, Jateline III is a hard template to configure. To me best is to install a quickstart-version locally and study the setup and configuration of all elements you want to use.
    For installation on an existing public site method is not different from other templates: just install the template, switch to this template as default in Template Manager, and put your modules in the right positions. But for configuration you can take a look at your local version of quickstart. demo setup.
    I myself prepare such a switch by first copying my site to a subdomain, than make all changes, and when all is tested, put this new version on main domain.
    Good luck,
    Micrantha
    neli Friend
    #328580
    Micrantha thank you for your responds.
    I know how to install the template.Also i know how to install modules and to put them in the right position.The problem is that i am following all the instructions that ja telline user guise says and my site is not working as it should..
    Its not that i am new to joomla..the problem has to do with the template and its modules…
This topic contains 7 replies, has 3 voices, and was last updated by  neli 14 years, 10 months ago.
