  • Mohamed H. Jurriah Friend
    #191933
    Hello
    I have some problems with my slideshow on the front-page. While I was changing the links, titles and pictures, the textbox disappeared and the pictures I want to have in the slideshow does not show up, except one of them.
    I have used the same settings in this link: http://static.joomlart.com/images/templates/j25/mendozite/slideshow.png
    .. and it still not working
    #511033
    Ninja Lead Moderator
    #511105
    You can try my suggestion here : link
    #511188
    <em>@Ninja Lead 396421 wrote:</em><blockquote>+ Copy it into modules/mod_jaslideshowlite/assets/elements/jagallery.php</blockquote>
    The folder name “elements” dosnt exist in the “assets” folder??
    I have tried to put the jagallery.php file in both folders, but that didnt solve the problem?
    #511344
    If elements folder doesn’t exist in assets folder then you might be is using old version of JA Slideshow Lite module. You can download latest version of this module from here and once upgraded you can try my solution given in earlier post posted at 11-04-2013 02:35 PM
    Don’t forget to clear cache from Admin area after finishing the updates
    #511733
    It have almost solved the problem…But now it only shows two, instead of three, pictures at a time?
    #511992
    In JA Sideshow Lite module supports to show three images at a time.
    + Slideshow Type: Custom
    + Image folder: with images format
    You can try it
    1. image_format
This topic contains 7 replies, has 2 voices, and was last updated by  Ninja Lead 11 years ago.
