  • guoltiero Friend
    #174688
    Hi everybody,
    May anybody help me? I have many problems with this template.
    #1- JA Bulletin and JA News Featured repeat same thumbnail. I don’t know why.
    #2- I want to put a background in body (grey zone).
    #3- I want to select one style for each category… for example green in Home, Default in Grandes Circuitos but it doesn’t work.
    #4- It takes so long time in loading. Why it doesn’t load faster?
    You can watch it out in http://www.ten-golf.es/25.
    Thanks!
    Manos Moderator
    #442275
    I just visited your website and i couldn’t see JA Bulletin module published anywhere, also i saw that you have many components and modules that you are not using and i would suggest that you should uninstall them in order to decrease you website page load time.
    I can see also in your articles that you have different images for instance an other image appears as the thumbnail and an other image popups up when you click that image ( example -> http://www.ten-golf.es/25/index.php?option=com_content&view=article&id=10586:las-brisas-se-pone-al-dia-sin-perder-de-vista-a-robert-trent-jones-v15-10586&catid=14:general&Itemid=4 )
    Also please use JA Extension Manager to update JA products and ( please update joomla since there is a security issue, to the latest version ).
    Manos Moderator
    #444854
    Hi guoltiero,
    Is this solved for you ? I tried to visit your website again but it appears that your web server is facing issues!
    Please let me know if there is anything else you need help with.
This topic contains 3 replies, has 2 voices, and was last updated by  Manos 12 years, 9 months ago.
