  • lailuluelo Friend
    #154081
    I don´t know where is the problem with overlapping but the article don´t respect his position and use the position of the modules on the right. I’m use notepad to erase html code and the problem didn’t fix.
    Could you help me?
    http:\www.luchamotera.com
    Thank you in advance
    joomlageeks Friend
    #354726
    The Problem is with the first 2 content that you have posted in the Home page. If you unpublish the first two articles “La edad para conducir ciclomotores se eleva de 14 a 15 años ” and “NOVEDADES DE LA REFORMA DE LA LEY SOBRE TRÁFICO Y SEGURIDAD VIAL ” the page looks neat. The images in the “NOVEDADES DE LA REFORMA DE LA LEY SOBRE TRÁFICO Y SEGURIDAD VIAL ” article are 680px in width, which is resulting in this layout problem.
    Please clean up the content code and re-try again. Even then if you end up in fail – then I can try cleaning up the content code for you.
    James NT
    lailuluelo Friend
    #354731
    Solved, the image resolution of other article is the problem
    joomlageeks Friend
    #354733
    Happy that you are able to fix the problem by yourself wit the little tips that was provided. Just checked back your website in different browsers. The layout looks clean.
    Good Luck.
This topic contains 4 replies, has 2 voices, and was last updated by  joomlageeks 14 years, 3 months ago.
