rafafuster Friend
rafafuster
- August 2014
September 8, 2014 at 7:15 pm #201164Good job. I like the template. It works pretty well. Good programming. I have only a problem. Small problem, but affects the functionality of the web based on a catalog. This is the Chronoconnectivity and it’s component to make data lists. No pages counter nor the combo to limit count for the list appears. ChronoForms seems that these parameters can’t load the sytem pagination from the template Sugite.
This is an example of how it works in the current page with another web template.:
http://www.signoslapidarios.org/inicio/consultas/signos-lapidarios/buscar-por-edificios
As you can see it works perfectly.
I would be grateful if I can explain how I can solve this problem.
Thank you very much and congratulations for your good work.
- November 2014
- 3854 times in 3563 posts
September 9, 2014 at 8:03 am #548814@rafafuster: Can you send me URL of your site and admin login are working on Chronoconnectivity component via private message? I will help you to check this bug with pagination Chronoconnectivity component.
rafafuster Friendrafafuster
- August 2014
September 9, 2014 at 6:34 pm #548910If it is necessary, I do a backup of the web and provide you the permissions. And also I prepare the test environment with a list or Chronoconnectivity and an associated ChronoForms (not ‘running pagination).
I Take this opportunity to attach you two images with screenshots of successful operation on the current template and wrong with Sugite template.
Thank you very much for everything. Sugite template is a good work. I’m glad for the service. Together we can make it even better.
Greetings-
Ninja Lead
- November 2014
September 10, 2014 at 8:56 am #548986On this case we could not support for that but I can help you to check this problem. You can clone on your site and config JA Sugite template work with Chronoconnectivity and an associated ChronoForms and pm me the info temporary site: URL of your site and admin access and FTP account. I will help you check and fix the problem directly on this site.
- August 2014
September 11, 2014 at 3:14 am #549118Okay, but I need a few days to prepare for the test environment. Thank you very much.
- November 2014
September 11, 2014 at 3:53 am #549121Let me know if temporary site is ready
- August 2014
July 14, 2015 at 4:59 pm #577389This month I have acquired one of your licenses. I am preparing the migration to joomla 3.4 and I needed to update the template. I think you should ensure updates templates that one acquires .
Moreover, I am delighted with the Sugite template. It has covered all my expectations. Only I have a problem. I have not resolved the pagination with ChronoForms component.
It desappears page counter and page ordenation when I activate the Sugite template.
Here and example:
If necessary I will provide you the user and access to FTP to see if you can help me.
Thank you very much .
- August 2014
July 14, 2015 at 4:59 pm #643686This month I have acquired one of your licenses. I am preparing the migration to joomla 3.4 and I needed to update the template. I think you should ensure updates templates that one acquires .
Here and example:
- August 2014
July 14, 2015 at 4:59 pm #742333This month I have acquired one of your licenses. I am preparing the migration to joomla 3.4 and I needed to update the template. I think you should ensure updates templates that one acquires .
Here and example:
- November 2014
July 15, 2015 at 3:23 am #577438I check on link above and see the pagination on your site is working fine, see the screenshot
How can I see the problem with page counter and page ordernation on your site. You can pm me admin login backend site and FTP account. I will help you to check it further
- November 2014
July 15, 2015 at 3:23 am #643735I check on link above and see the pagination on your site is working fine, see the screenshot
- November 2014
July 15, 2015 at 3:23 am #742382I check on link above and see the pagination on your site is working fine, see the screenshot
Viewing 12 posts - 1 through 12 (of 12 total)This topic contains 12 replies, has 2 voices, and was last updated by Ninja Lead 9 years, 6 months ago.
