  • stanpolman Friend
    #172508
    I have installed Teline iv and Joomla 1.7 quick set-up. There are two problems:
    The first problem: When I insert a picture in an article, there is no space between the picture and the text.
    In the demo I see in the html code:
    <div><img class=”caption” src=”images/stories/….
    And in the category overview the text and the picture is okay.
    But when I insert a picture in a new article the html code is:
    <p><img src=”images/stories/….
    And there is no space between the picture and the text.
    I can add class=”caption” manually, but that is not the intention, I suppose. What is the solution?
    The second problem: The background (?) of ja-nws default layout is not white but grey. It has to be white as in the demo. How can I fix it?
    TomC Moderator
    #432830
    <em>@stanpolman 293298 wrote:</em><blockquote>I have installed Teline iv and Joomla 1.7 quick set-up. There are two problems:
    I can add class=”caption” manually, but that is not the intention, I suppose. What is the solution?</blockquote>
    Can you provide a link to a page within your site that is displaying this particular problem?
    <em>@stanpolman 293298 wrote:</em><blockquote>The second problem: The background (?) of ja-nws default layout is not white but grey. It has to be white as in the demo. How can I fix it?</blockquote>
    This is actually an image used for the background – which can be found within /templates/ja_teline_iv/css/template.css
    at line 453
    #ja-container .main-inner1 {
    background: url(../images/stripe-bg-2.png) #ddd;
    margin: 0;
    padding: 2px;
    Simply remove the background image and (if necessary), set the color to #fff
    stanpolman Friend
    TomC Moderator
    #432841
    <em>@stanpolman 293317 wrote:</em><blockquote>You can see it at http://www.dedigitalemeergids.nl/index.php/nieuws/nieuws-uit-oostelijk-amsterdam/algemeen-nieuws</blockquote>
    Okay, I set “Optimize CSS” to “No” within your Template Manager–General Settings (so I could try to better identify the CSS you need to work with). You can setit back to “Join & Minify” when we are through working on this issue.
    I am no entirely certain if this is the absolute correct CSS file (as I believe “addon.css” often refers to compressed css (though don’t quote me on that)) . . . but it’s worth a shot . . .
    Within your template file structure, look and see if you can find the following –>
    /plugins/system/jat3/jat3/base-themes/default/css/addon.css
    if “addon.css” is there, look at lines 19-38
    html, body, div, span, applet, object, iframe,
    h1, h2, h3, h4, h5, h6, p, blockquote, pre,
    a, abbr, acronym, address, big, cite, code,
    del, dfn, em, img, ins, kbd, q, s, samp,
    small, strike, strong, sub, sup, tt, var,
    b, u, i, center,
    dl, dt, dd, ol, ul, li,
    fieldset, form, label, legend,
    table, caption, tbody, tfoot, thead, tr, th, td,
    article, aside, canvas, details, embed,
    figure, figcaption, footer, header, hgroup,
    menu, nav, output, ruby, section, summary,
    time, mark, audio, video {
    margin: 0;
    padding: 0px;
    border: 0;
    /*font-size: 100%; -- Keeping the default behavior on font aesthetic*/
    /*font: inherit; -- Keeping the default behavior on font aesthetic*/
    /*vertical-align: baseline;*/
    change the “padding” property to “padding-right: 10px;” – so it will look as follows:
    b, u, i, center,
    margin: 0;
    border: 0;
    SAVE CHANGES – CLEAR CACHE – REFRESH PAGE
    Let me know if this is close to the result you are hoping for.
    stanpolman Friend
    #432849
    Thanks Tom,
    Issue one has fixed.
    But nothing changed with the pictures and the text. The padding setting does not work.
    TomC Moderator
    #432850
    <em>@stanpolman 293329 wrote:</em><blockquote>Thanks Tom,
    But nothing changed with the pictures and the text. The padding setting does not work.</blockquote>
    So you were able to find that css file (addon.css) ??
    stanpolman Friend
    #432904
    Yes, I found it and I have changed te code. But nothing changed at the front-end.
    stanpolman Friend
    #433105
    Still always I have a problem with publishing pictures.
    Whem I insert a picture with the text editor by myself the picture will be published without space between the text and the picture. When I look at the html code in the text editor I see:
    But when I look at the html code in the text editor of the demo articles already are in Teleine iv Joomla 1.70 I have downloaded, the html code is:
    My concrete question is: how can I publish pictures without adjusting the html code every time?
This topic contains 8 replies, has 2 voices, and was last updated by  stanpolman 13 years ago.
