parodoxical Friend
parodoxical
- October 2008
October 14, 2008 at 12:55 pm #134395Hi,
I’m trying to figure out why the Product Slider & Featured Products is showing no picture. The rest is working fine. I know the pictures are all loaded. Anyone have an Idea? Here is what’s happening: http://www.baju-gaul.com All still standard Joomla, Virtuemart & Ja Mesolite installation.Brian Sutisna
zeolite Friendzeolite
- February 2007
- 5 times in 2 posts
October 14, 2008 at 4:28 pm #275256I get installation on this link
parodoxical Friendparodoxical
- October 2008
October 14, 2008 at 4:30 pm #275257Thank you very much. I’m trying to reinstall everything again. And see if it works.:)
shertmann Friendshertmann
- September 2008
- 42 times in 26 posts
October 14, 2008 at 7:53 pm #275273hey you must finish your joomla installation and remove the installation folder because you have that open for a security threat
- October 2008
October 15, 2008 at 7:40 am #275371Thank you Shertmann, I’ve completed my new installation, however it’s still the same. More problems now, is that the top right Currency & Shopping card isn’t aligned. Same with the Products thumbnail isn’t showing. The featured products, supposed to do 2 lines of 4 is now showing only 1 line of 3 products. I’m confused now. 🙁 Any advice? Thank you. http://www.baju-gaul.com
For php setting, http://www.baju-gaul.com/phpinfo.php :confused:Here’s a picture of it.
- October 2008
October 16, 2008 at 7:13 am #275578I finally got this problem solved. Thank you for all that tried to help. Apparently its a problem from Hosting server side on file permission. Again thanks. :laugh:
October 16, 2008 at 8:18 am #275585What did you do to solve the problem? why dont you share the solution with the rest of us?
- October 2008
October 16, 2008 at 9:59 am #275626Hi Ågebror,
What I did was edit the components/com_virtuemart/show_image_in_imgtag.php and changed from readfile($fileout); to echo file_get_contents($fileout); Also checked the permission of folder to writable. And it worked fine. Hope this will help out those who need it. Thanks.1 user says Thank You to parodoxical for this useful post
- September 2008
October 16, 2008 at 10:42 pm #275760congrats is good to now that
- October 2008
October 24, 2008 at 4:53 am #276788Hi all,
I’ve managed to get all the installation done and working in the Frontend don’t seem to have any problems. The pictures are showing. But I’m getting wierd errors when using the backend. Basically all the Save, Apply and Cancel button don’t work for virtuemart. Any of the Icon’s on the top right isn’t working. Anyone has any Idea how to solve this? The error I get is:<blockquote>MM_swapImage is not defined hxxp://www.baju-gaul.com/administrator/index.php?page=product.product_list&category_id=0&product_id=30&func=changePublishState&option=com_virtuemart&vmtoken=d7e52503cd242988a4dc2698acba8079&task=publish (line 713)
MM_swapImage is not defined hxxp://www.baju-gaul.com/administrator/index.php?page=product.product_list&category_id=0&product_id=30&func=changePublishState&option=com_virtuemart&vmtoken=d7e52503cd242988a4dc2698acba8079&task=publish (line 191)
vm_submitButton is not defined </blockquote>
I’m using the quickstart from JA Mesolite with editing of components/com_virtuemart/show_image_in_imgtag.php and changed from readfile($fileout); to echo file_get_contents($fileout);. The rest is default and no other module installed. Thank you.
- October 2008
October 25, 2008 at 12:44 pm #276894Hi All,
I’ve finally managed to fix the problem by uninstalling the Virtuemart module and reinstalling it with the Later Nightlybuild package. The thumbnails don’t work, but I its fixable by editing the components/com_virtuemart/show_image_in_imgtag.php and changed from readfile($fileout); to echo file_get_contents($fileout);
Hope this helps. -
This topic contains 11 replies, has 4 voices, and was last updated by parodoxical 15 years, 12 months ago.
