October 21, 2007 at 10:38 pm #123344
I have been trying to install Ja Teline as a quickstart package… but I am having a lot of problems during installation. I have tried installing it 7 times now and I continue getting the same errors. I have installed other quickstart packages and never had any problems. (Using 1and1 for hosting and mysql databases).
During installation, I put in my MySQL database information and it takes me to the next step of installation where i’m supposed to define my site. It allows me to go to the next tab (so my MySQL info is correct) but on the next tab it says that there are errors in lines of the mysql database. If I try installing it without including sample data (dropping old tables) it will install fine… but I want the sample data within the site! (that’s the point of the quickstart!)
I watched the video demo when it was still up on quickstart with teline, but I don’t have cpanel with the installation.
After 7 attempts at installing this quickstart, I’m getting incredibly frustrated. I have the teline template up, is there a way to manually insert the info in mysql?
I’m just lost, any idea what’s going on?
November 2, 2007 at 1:34 pm #231992This what I found:
1. Delete the .htaccess file
2. Run http://localhost/teline/installation/xraydevil Friendxraydevil
- June 2007
- 2 times in 1 posts
January 16, 2008 at 3:24 pm #236527hi,
i have the same problem.
this is my error log:
[PHP]SQL=You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near ‘DEFAULT CHARSET=utf8’ at line 19 SQL=CREATE TABLE `jos_banner` (
n `bid` int(11) NOT NULL auto_increment,
n `cid` int(11) NOT NULL default ‘0’,
n `type` varchar(10) NOT NULL default ‘banner’,
n `name` varchar(50) NOT NULL default ”,
n `imptotal` int(11) NOT NULL default ‘0’,
n `impmade` int(11) NOT NULL default ‘0’,
n `clicks` int(11) NOT NULL default ‘0’,
n `imageurl` varchar(100) NOT NULL default ”,
n `clickurl` varchar(200) NOT NULL default ”,
n `date` datetime default NULL,
n `showBanner` tinyint(1) NOT NULL default ‘0’,
n `checked_out` tinyint(1) NOT NULL default ‘0’,
n `checked_out_time` datetime NOT NULL default ‘0000-00-00 00:00:00’,
n `editor` varchar(50) default NULL,
n `custombannercode` text,
n PRIMARY KEY (`bid`),
n KEY `viewbanner` (`showBanner`)
n) ENGINE=MyISAM AUTO_INCREMENT=3 DEFAULT CHARSET=utf8:
CREATE TABLE `#__banner` (
= = = = = = = = = =SQL=Table ‘maam_v2db.jos_banner’ doesn’t exist SQL=–
n– Dumping data for table `jos_banner`
n–
n
n
n/*!40000 ALTER TABLE `jos_banner` DISABLE KEYS */:
— Dumping data for table `#__banner`
—/*!40000 ALTER TABLE `#__banner` DISABLE KEYS */
= = = = = = = = = =SQL=Table ‘maam_v2db.jos_banner’ doesn’t exist SQL=LOCK TABLES `jos_banner` WRITE:
LOCK TABLES `#__banner` WRITE
= = = = = = = = = =SQL=Table ‘maam_v2db.jos_banner’ doesn’t exist SQL=INSERT INTO `jos_banner` VALUES (1,1,’banner’,’OSM 1′,0,1787,9,’osmbanner1.png’,’http://www.opensourcematters.org’,’2004-07-07 15:31:29′,1,0,’0000-00-00 00:00:00′,NULL,NULL),(2,1,’banner’,’OSM 2′,0,1664,13,’osmbanner2.png’,’http://www.opensourcematters.org’,’2004-07-07 15:31:29′,1,0,’0000-00-00 00:00:00′,NULL,NULL):
INSERT INTO `#__banner` VALUES (1,1,’banner’,’OSM 1′,0,1787,9,’osmbanner1.png’,’http://www.opensourcematters.org’,’2004-07-07 15:31:29′,1,0,’0000-00-00 00:00:00′,NULL,NULL),(2,1,’banner’,’OSM 2′,0,1664,13,’osmbanner2.png’,’http://www.opensourcematters.org’,’2004-07-07 15:31:29′,1,0,’0000-00-00 00:00:00′,NULL,NULL)
= = = = = = = = = =SQL=Table ‘maam_v2db.jos_banner’ doesn’t exist SQL=/*!40000 ALTER TABLE `jos_banner` ENABLE KEYS */:
/*!40000 ALTER TABLE `#__banner` ENABLE KEYS */
= = = = = = = = = =SQL=You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near ‘DEFAULT CHARSET=utf8’ at line 11 SQL=CREATE TABLE `jos_bannerclient` (
n `cid` int(11) NOT NULL auto_increment,
n `name` varchar(60) NOT NULL default ”,
n `contact` varchar(60) NOT NULL default ”,
n `email` varchar(60) NOT NULL default ”,
n `extrainfo` text NOT NULL,
n `checked_out_time` time default NULL,
n PRIMARY KEY (`cid`)
n) ENGINE=MyISAM AUTO_INCREMENT=2 DEFAULT CHARSET=utf8:
CREATE TABLE `#__bannerclient` (
PRIMARY KEY (`cid`)
= = = = = = = = = =SQL=Table ‘maam_v2db.jos_bannerclient’ doesn’t exist SQL=–
n– Dumping data for table `jos_bannerclient`
n–
n
n
n/*!40000 ALTER TABLE `jos_bannerclient` DISABLE KEYS */:
— Dumping data for table `#__bannerclient`
—/*!40000 ALTER TABLE `#__bannerclient` DISABLE KEYS */
= = = = = = = = = =SQL=Table ‘maam_v2db.jos_bannerclient’ doesn’t exist SQL=LOCK TABLES `jos_bannerclient` WRITE:
LOCK TABLES `#__bannerclient` WRITE
= = = = = = = = = =SQL=Table ‘maam_v2db.jos_bannerclient’ doesn’t exist SQL=INSERT INTO `jos_bannerclient` VALUES (1,’Open Source Matters’,’Administrator’,’admin@opensourcematters.org’,”,0,’00:00:00′,NULL):
INSERT INTO `#__bannerclient` VALUES (1,’Open Source Matters’,’Administrator’,’admin@opensourcematters.org’,”,0,’00:00:00′,NULL)
= = = = = = = = = =SQL=Table ‘maam_v2db.jos_bannerclient’ doesn’t exist SQL=/*!40000 ALTER TABLE `jos_bannerclient` ENABLE KEYS */:
/*!40000 ALTER TABLE `#__bannerclient` ENABLE KEYS */
= = = = = = = = = =SQL=You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near ‘DEFAULT CHARSET=utf8’ at line 12 SQL=CREATE TABLE `jos_bannerfinish` (
n `type` varchar(10) NOT NULL default ”,
n `impressions` int(11) NOT NULL default ‘0’,
n `imageurl` varchar(50) NOT NULL default ”,
n `datestart` datetime default NULL,
n `dateend` datetime default NULL,
n) ENGINE=MyISAM DEFAULT CHARSET=utf8:
CREATE TABLE `#__bannerfinish` (
PRIMARY KEY (`bid`)
= = = = = = = = = =SQL=Table ‘maam_v2db.jos_bannerfinish’ doesn’t exist SQL=–
n– Dumping data for table `jos_bannerfinish`
n–
n
n
n/*!40000 ALTER TABLE `jos_bannerfinish` DISABLE KEYS */:
– – – – – – – – – -[/PHP]
and so on and so on ….I deleteted the .htaccess file. is there no possibilty to install the routine with the quickstart teline template?
regards
frankxraydevil Friendxraydevil
- June 2007
January 16, 2008 at 4:01 pm #236530solved.
i found this thread. -
This topic contains 4 replies, has 3 voices, and was last updated by xraydevil 16 years, 11 months ago.
