  • donovan Friend
    #116952
    morning…
    Was wondering if someone could point me in the right direction. Per the readme file it states:
    Top Menu –> use “-top” as module prefix and “header” as module position for mainmenu.
    Menutype is “Flat list”
    Bottom Menu –> use “-bot” as module prefix and “bottom” as module position for mainmenu.
    were is the module prefix set at? I can find the Module Class Suffix but no Module Prefix
    thanks…
    nathanbohn Friend
    #209971
    i think it is just a typographical error.
    donovan Friend
    #209978
    nathanbohni think it is just a typographical error.
    OK, then that leads to another question then because if it is a typo, then using the module sufix and putting -top in it doesn’t work.
    now what?
    donovan Friend
    #209979
    donovanOK, then that leads to another question then because if it is a typo, then using the module sufix and putting -top in it doesn’t work.
    now what?
    But puting -top in Menu Class Suffix causes the color to appear correctly in the menu.
This topic contains 4 replies, has 2 voices, and was last updated by  donovan 18 years, 4 months ago.
